查看: 6631|回复: 2
[ThreadX全家桶] ThreadX是收费的还是免费的呢?
发表于 2021-5-5 21:15:21 | 显示全部楼层 |阅读模式
我现在用的FREERTOS,今天看到咱们这个版块,正在看pdf说明。
 楼主| 发表于 2021-5-5 21:17:49 | 显示全部楼层
因为freertos不需要移植工作,在STM32 cubeMX软件里直接就可以生成了。然而,在MDK调试时,却不能直观的观察操作系统的一些情况。
发表于 2021-5-6 08:00:29 | 显示全部楼层
免费厂家列表,还差持续增加中
https://github.com/azure-rtos/th ... CENSED-HARDWARE.txt
  1. LICENSED HARDWARE LIST
  2. Last Updated: 2021-04-01
  3. Microsoft has entered into OEM Agreements with manufacturers of the following
  4. microprocessors and microcontrollers (the “hardware”) to enable those
  5. manufacturers to include and distribute Azure RTOS in certain hardware. If you
  6. have obtained and/or are developing on microprocessor(s) and/or
  7. microcontroller(s) (“hardware”) listed below you inherit the “Distribution and
  8. Production Use” rights in Section 2 of the Microsoft Software License Terms for
  9. Microsoft Azure RTOS. If hardware is not listed below, you do not have those
  10. rights.
  11. STMicroelectronics:
  12.     STM32 MCUs
  13.     STM32 MPUs
  14. MediaTek:
  15.     MT3620 MCU (Azure Sphere)
  16. Microchip:
  17.     PIC 32-bit MCUs
  18.     SAM 32-bit MCUs
  19.     SAM 32-bit MPUs
  20. NXP:
  21.     i.MX RT10xx and RT116x/7x series crossover MCUs
  22.     LPC5500 series
  23. Renesas:
  24.     Synergy Platform
  25.     RX Family of MCUs
  26.     RA Family of MCUs
  27.     RZ Family of MPUs
  28. --------------------------------------------------------------------------------
  29. More coming soon. Please check back frequently for updates.
GMT+8, 2026-11-23 20:46 , Processed in 0.273195 second(s), 24 queries .
