查看: 6921|回复: 4
[HAL] RTC精密数字校准
发表于 2021-4-30 16:57:55 | 显示全部楼层 |阅读模式
库函数HAL_RTCEx_SetSmoothCalib实现精密校准,假设RTC一天快了1秒,怎么理解使用这个函数呢?
发表于 2021-5-1 08:24:55 | 显示全部楼层
看了下这个函数,只有简单的寄存器设置,这个有必要研究下手册了
  1. /**
  2.   * @brief  Set the Smooth calibration parameters.
  3.   * @param  hrtc RTC handle
  4.   * @param  SmoothCalibPeriod Select the Smooth Calibration Period.
  5.   *          This parameter can be can be one of the following values :
  6.   *             @arg RTC_SMOOTHCALIB_PERIOD_32SEC: The smooth calibration period is 32s.
  7.   *             @arg RTC_SMOOTHCALIB_PERIOD_16SEC: The smooth calibration period is 16s.
  8.   *             @arg RTC_SMOOTHCALIB_PERIOD_8SEC: The smooth calibration period is 8s.
  9.   * @param  SmoothCalibPlusPulses Select to Set or reset the CALP bit.
  10.   *          This parameter can be one of the following values:
  11.   *             @arg RTC_SMOOTHCALIB_PLUSPULSES_SET: Add one RTCCLK pulse every 2*11 pulses.
  12.   *             @arg RTC_SMOOTHCALIB_PLUSPULSES_RESET: No RTCCLK pulses are added.
  13.   * @param  SmoothCalibMinusPulsesValue Select the value of CALM[8:0] bits.
  14.   *          This parameter can be one any value from 0 to 0x000001FF.
  15.   * @note   To deactivate the smooth calibration, the field SmoothCalibPlusPulses
  16.   *         must be equal to SMOOTHCALIB_PLUSPULSES_RESET and the field
  17.   *         SmoothCalibMinusPulsesValue must be equal to 0.
  18.   * @retval HAL status
  19.   */
  20. HAL_StatusTypeDef HAL_RTCEx_SetSmoothCalib(RTC_HandleTypeDef * hrtc, uint32_t SmoothCalibPeriod, uint32_t SmoothCalibPlusPulses, uint32_t SmoothCalibMinusPulsesValue)
  21. {
  22.   uint32_t tickstart;
  23.   /* Check the parameters */
  24.   assert_param(IS_RTC_SMOOTH_CALIB_PERIOD(SmoothCalibPeriod));
  25.   assert_param(IS_RTC_SMOOTH_CALIB_PLUS(SmoothCalibPlusPulses));
  26.   assert_param(IS_RTC_SMOOTH_CALIB_MINUS(SmoothCalibMinusPulsesValue));
  27.   /* Process Locked */
  28.   __HAL_LOCK(hrtc);
  29.   hrtc->State = HAL_RTC_STATE_BUSY;
  30.   /* Disable the write protection for RTC registers */
  31.   __HAL_RTC_WRITEPROTECTION_DISABLE(hrtc);
  32.   /* check if a calibration operation is pending */
  33. #if defined(RTC_ICSR_RECALPF)
  34.   if ((hrtc->Instance->ICSR & RTC_ICSR_RECALPF) != 0U)
  35. #endif /* RTC_ICSR_RECALPF */
  36. #if defined(RTC_ISR_RECALPF)
  37.     if ((hrtc->Instance->ISR  & RTC_ISR_RECALPF)  != 0U)
  38. #endif /* RTC_ISR_RECALPF */
  39.     {
  40.       tickstart = HAL_GetTick();
  41.       /* Wait for pending calibration operation to finish */
  42. #if defined(RTC_ICSR_RECALPF)
  43.       while ((hrtc->Instance->ICSR & RTC_ICSR_RECALPF) != 0U)
  44. #endif /* RTC_ICSR_RECALPF */
  45. #if defined(RTC_ISR_RECALPF)
  46.         while ((hrtc->Instance->ISR  & RTC_ISR_RECALPF)  != 0U)
  47. #endif /* RTC_ISR_RECALPF */
  48.         {
  49.           if ((HAL_GetTick() - tickstart) > RTC_TIMEOUT_VALUE)
  50.           {
  51.             /* Enable the write protection for RTC registers */
  52.             __HAL_RTC_WRITEPROTECTION_ENABLE(hrtc);
  53.             /* Change RTC state */
  54.             hrtc->State = HAL_RTC_STATE_TIMEOUT;
  55.             /* Process Unlocked */
  56.             __HAL_UNLOCK(hrtc);
  57.             return HAL_TIMEOUT;
  58.           }
  59.         }
  60.     }
  61.   /* Configure the Smooth calibration settings */
  62.   MODIFY_REG(hrtc->Instance->CALR, (RTC_CALR_CALP | RTC_CALR_CALW8 | RTC_CALR_CALW16 | RTC_CALR_CALM), (uint32_t)(SmoothCalibPeriod | SmoothCalibPlusPulses | SmoothCalibMinusPulsesValue));
  63.   /* Enable the write protection for RTC registers */
  64.   __HAL_RTC_WRITEPROTECTION_ENABLE(hrtc);
  65.   /* Change RTC state */
  66.   hrtc->State = HAL_RTC_STATE_READY;
  67.   /* Process Unlocked */
  68.   __HAL_UNLOCK(hrtc);
  69.   return HAL_OK;
  70. }
发表于 2021-5-1 08:33:55 | 显示全部楼层
找到了,有个专门的软件包和相关文档。
https://www.st.com/en/embedded-software/x-cube-rtc.html
More we do, more we can do.
发表于 2021-5-1 14:36:55 | 显示全部楼层
我们是有自己做高精度时钟仪,能到0.01秒/天
 楼主| 发表于 2021-5-6 15:34:49 | 显示全部楼层
eric2013 发表于 2021-5-1 08:33
找到了,有个专门的软件包和相关文档。
仍然一头雾水,想要那种傻瓜式的,谢谢分享
GMT+8, 2026-10-26 04:25 , Processed in 0.208665 second(s), 24 queries .
