查看: 8476|回复: 1
[有问必答] STM32大容量芯片工程模板换成小容量芯片工程报错
发表于 2021-4-4 00:07:10 | 显示全部楼层 |阅读模式
linking...
.\Flash\Obj\output.axf: Error: L6406E: No space in execution regions with .ANY selector matching startup_stm32f10x_hd.o(STACK).
.\Flash\Obj\output.axf: Error: L6406E: No space in execution regions with .ANY selector matching adxl345.o(.data).
.\Flash\Obj\output.axf: Error: L6406E: No space in execution regions with .ANY selector matching myiic.o(.data).
.\Flash\Obj\output.axf: Error: L6407E: Sections of aggregate size 0x8008 bytes could not fit into .ANY selector(s).
Not enough information to list image symbols.
Not enough information to list load addresses in the image map.
Finished: 2 information, 0 warning and 4 error messages.
".\Flash\Obj\output.axf" - 4 Error(s), 6 Warning(s).
Target not created.
使用硬汉的工程模板,MDK换成小容量芯片,就会出现这种情况担心程序并不大,加个流水灯都行,内存溢出吗?
求大佬解答!!!!
感谢怎么搞
发表于 2021-4-4 10:03:45 | 显示全部楼层
先看下未转化前的map文件RAM分配情况,优化后转化。
GMT+8, 2026-11-28 16:48 , Processed in 1.163128 second(s), 24 queries .
