查看: 10751|回复: 12
[ThreadX全家桶] ThreadX全家福之H745
发表于 2021-3-30 14:35:17 | 显示全部楼层 |阅读模式
最近一段时间折腾了手里的NUCLEO-H745的板子,借鉴x-cube-azrtos-h7和楼主的例子,移植了ThreadX\NetDuo\USBX\FileX.
目前实现的功能有:
1. ThreadX跑在480MHz,运行下面的任务
main_tag:       [tick:0001037453] ===============================================================
main_tag:       [tick:0001037453] OS CPU Usage =  1.05%
main_tag:       [tick:0001037453]    Prio StackSize CurStack MaxStack Taskname
main_tag:       [tick:0001037453]     2     4092      279      507    App Task Start
main_tag:       [tick:0001037453]    30     4092      255      255    App Task STAT
main_tag:       [tick:0001037453]    31     4092       87       71    App Task IDLE
main_tag:       [tick:0001037453]     7     4092      559      355    App Task USER
main_tag:       [tick:0001037453]     6     8188      191      655    App NETX Pro
main_tag:       [tick:0001037453]    25     1020      143      339    ux_app_thread
main_tag:       [tick:0001037453]    29     1020      151      151    mouse_app_thread
main_tag:       [tick:0001037453]    29     1020      135      135    keyboard_app_thread
main_tag:       [tick:0001037453]    29     2044      175     1227    msc_app_thread
main_tag:       [tick:0001037453]    20     2044      199      847    ux_system_host_enum_thread
main_tag:       [tick:0001037453]     2     1020      199      199    ux_host_stack_hcd_thread
main_tag:       [tick:0001037453]    28     4092      311      695    NetX IP Instance 0
main_tag:       [tick:0001037453]     3     4092      267      531    NetX DHCP Client
main_tag:       [tick:0001037453]    10     1020       95      247    App Main thread
main_tag:       [tick:0001037453]     5     1020       95      511    App SNTP Thread
main_tag:       [tick:0001037453]    20     1020      119      255    ux_host_storage_thread
main_tag:       [tick:0001037454]     0     1020      155      175    System Timer Thread
2.插入网线到路由器,DHCP自动获取IP,网络可用的话通过ntp.aliyun.com自动更新本地UTC时间,同时开启TCP server,目前PING包1400字节,>3百万包级别没有丢包。通过大文件发送文件给板子,大概能到5MB\s,我估计是硬件的限制了。
main_tag:       [tick:0000000000] AppTaskStat Start
main_tag:       [tick:0000000000] AppTaskIDLE Start
main_tag:       [tick:0000000102] CHIP ID:002200253438511336353232
main_tag:       [tick:0000000102] AppTaskLED Start
main_tag:       [tick:0000000102] AppTaskUser Start
demo_nex_tag:   [tick:0000000354] nx_system_initialize
demo_nex_tag:   [tick:0000000354] nx_packet_pool_create
demo_nex_tag:   [tick:0000000354] nx_ip_created
SNTP_tag::      [tick:0000000354] App_Main_Thread_Entry
demo_nex_tag:   [tick:0000000355] nx_arp_enable
demo_nex_tag:   [tick:0000000355] nx_ip_fragment_enable
demo_nex_tag:   [tick:0000000355] nx_tcp_enable
demo_nex_tag:   [tick:0000000355] nx_udp_enable
demo_nex_tag:   [tick:0000000355] nx_icmp_enable
demo_nex_tag:   [tick:0000000355] nx_tcp_socket_create
demo_nex_tag:   [tick:0000000355] nx_tcp_server_socket_listen
NO_TAG          [tick:0000000554] USB OTG HS in FS Dual_Class Host
NO_TAG          [tick:0000000554] USB Host library started
NO_TAG          [tick:0000000554] Starting Application
NO_TAG          [tick:0000000554] Connect your USB Device
main_tag:       [tick:0000003102] OS CPU Usage =  0.34%
main_tag:       [tick:0000004102] OS CPU Usage =  0.34%
main_tag:       [tick:0000005102] OS CPU Usage =  0.34%
SNTP_tag::      [tick:0000005169] STM32 IpAddress: 172.21.8.51
SNTP_tag::      [tick:0000005170] App_SNTP_Thread_Entry
SNTP_tag::      [tick:0000005191] SNTP client connected to NTP server : < ntp.aliyun.com >
SNTP_tag::      [tick:0000005216] SNTP update:Mar 30, 2021 6:32:52.60 UTC
3.USB HOST支持HID、Storage Class,插入键盘鼠标可以自动识别,并打印对应的位置信息,插入U盘自动创建文件并且做读写测试,因为是Full Speed,所以速度不是很快。
NO_TAG          [tick:0000017997] HID Client Plugged
NO_TAG          [tick:0000017997] Current_class -> ux_host_class_name:ux_host_class_hid
NO_TAG          [tick:0000017997] HID_Mouse_Device
NO_TAG          [tick:0000017997] PID: 0x1100
NO_TAG          [tick:0000017997] VID: 0x24ae
NO_TAG          [tick:0000017997] USB HID Host Mouse App...
NO_TAG          [tick:0000017998] Mouse is ready...
NO_TAG          [tick:0000017998] ux_dev_info.Device_Type:2
NO_TAG          [tick:0000017999] Current_class -> ux_host_class_name:ux_host_class_hid
main_tag:       [tick:0000018102] OS CPU Usage =  7.93%
NO_TAG          [tick:0000018628] Pos_x = 4 Pos_y= 0
NO_TAG          [tick:0000018638] Pos_x = 9 Pos_y= -1
NO_TAG          [tick:0000018648] Pos_x = 14 Pos_y= -2
NO_TAG          [tick:0000018658] Pos_x = 19 Pos_y= -3
NO_TAG          [tick:0000018668] Pos_x = 29 Pos_y= -4
NO_TAG          [tick:0000018678] Pos_x = 33 Pos_y= -5
NO_TAG          [tick:0000018688] Pos_x = 34 Pos_y= -5
NO_TAG          [tick:0000018698] Pos_x = 37 Pos_y= -5
NO_TAG          [tick:0000018748] Pos_x = 43 Pos_y= -5
NO_TAG          [tick:0000018758] Pos_x = 47 Pos_y= -5
NO_TAG          [tick:0000056433] USB Device Plugged
NO_TAG          [tick:0000056433] USB Mass Storage Device Found
NO_TAG          [tick:0000056433] PID: 0xef18
NO_TAG          [tick:0000056433] VID: 0x23a9
NO_TAG          [tick:0000056433] Start Files operations
NO_TAG          [tick:0000056435] File TEST.TXT Created
NO_TAG          [tick:0000056435] Write Process ......
NO_TAG          [tick:0000056704] Write Process Success
NO_TAG          [tick:0000056704] Read Process  ......
NO_TAG          [tick:0000056704] Read Process Success
NO_TAG          [tick:0000056704] Speed test Process  ......
main_tag:       [tick:0000057102] OS CPU Usage = 15.58%
main_tag:       [tick:0000058102] OS CPU Usage = 15.47%
NO_TAG          [tick:0000059031] Write cost : 2325ms   Average speed: 902000B/S (880KB/S)
main_tag:       [tick:0000059102] OS CPU Usage = 15.56%
main_tag:       [tick:0000060102] OS CPU Usage =  8.31%
NO_TAG          [tick:0000061088] Read cost : 2044ms   Average speed: 1026003B/S (1001KB/S)
NO_TAG          [tick:0000061088] Speed test Process Success
NO_TAG          [tick:0000061088] File Closed
NO_TAG          [tick:0000061088] End Files operations
链接:https://pan.baidu.com/s/1gN9kQIwneQU07Xp-2hudtA
提取码:tjrm
发表于 2021-3-30 14:47:31 | 显示全部楼层
谢谢楼主分享。
 楼主| 发表于 2021-3-30 15:04:05 | 显示全部楼层
硬汉哥,其实我有个问题想咨询下您,我需要用USBX去驱动通讯模块,一般它都不是标准的class,那么需要用什么样的函数去实现呢?
我试了注册_ux_system_host_class_cdc_acm_name和_ux_system_host_class_dpump_name,但是ux_host_error_callback都给我返回UX_DEVICE_ENUMERATION_FAILURE,不知道要改哪里,难道需要自己写个class?
发表于 2021-3-31 09:06:58 | 显示全部楼层
jacksimcom 发表于 2021-3-30 15:04
硬汉哥,其实我有个问题想咨询下您,我需要用USBX去驱动通讯模块,一般它都不是标准的class,那么需要用 ...
UBSX的USB Host功能我还没有用过
发表于 2021-12-5 10:31:36 | 显示全部楼层
楼主位文件已过期
发表于 2021-12-5 21:31:40 | 显示全部楼层
现在才看到这个牛逼的帖子,只可惜,文件已过期,能否重新上传一下 ????
发表于 2021-12-6 14:50:20 | 显示全部楼层
这些功能在ST的H7 ThreadX软件包里面都已经做了。
发表于 2021-12-6 17:13:34 | 显示全部楼层
现在有段时间没有捣鼓这个东东了,目前在捣鼓蓝牙,搞的头大呀,哎,
发表于 2021-12-7 09:12:48 | 显示全部楼层
用的哪家的蓝牙芯片。
发表于 2021-12-10 16:07:50 | 显示全部楼层
eric2013 发表于 2021-12-7 09:12
用的哪家的蓝牙芯片。
ti 的 cc2540
发表于 2025-7-11 10:33:17 | 显示全部楼层
现在才看到这么牛逼的帖子,想下载时,发现已经过期了,不知道楼主还能不能看到,重传一份。
发表于 2025-7-17 07:37:58 | 显示全部楼层
安装 CUBEMX 的 THREADX 包里面已经提供这些工程了,你可以参考 \STM32Cube\Repository\Packs\STMicroelectronics\X-CUBE-AZRTOS-H7\3.4.0\Projects\STM32H747I-DISCO\Applications
发表于 2025-10-17 19:04:13 | 显示全部楼层
能重新分享一下连接吗?已过期用不了了。大佬
GMT+8, 2026-1-10 17:45 , Processed in 0.054646 second(s), 24 queries .
