查看: 14369|回复: 21
[辅助工具] 分享一个Cortex M 的FLASH算法提取器,用来解析FLM或FLX文件,使用H7-TOOL中的算法代码
发表于 2021-3-22 11:53:02 | 显示全部楼层 |阅读模式
感谢H7-TOOL的开源,我把其中FLM中提取FLASH下载算法的代码移植到了PC上,由原来的C 转成了C#
由于C#没有指针,移植的过程相当痛苦
特意来分享一下
软件界面:
点击保存:
.c文件里面的内容
  1. #include "S29JL032H_BOT.h"
  2. static const uint8_t  flash_code[] = {
  3.     0x00, 0xBE, 0x0A, 0xE0, 0x0D, 0x78, 0x2D, 0x06, 0x68, 0x40, 0x08, 0x24, 0x40, 0x00, 0x00, 0xD3,
  4.     0x58, 0x40, 0x64, 0x1E, 0xFA, 0xD1, 0x49, 0x1C, 0x52, 0x1E, 0x00, 0x2A, 0xF2, 0xD1, 0x70, 0x47,
  5.     0x10, 0xB5, 0x01, 0x88, 0x4E, 0x4C, 0xC1, 0xF3, 0x80, 0x13, 0x4C, 0x44, 0x21, 0x60, 0x01, 0x88,
  6.     0x21, 0x60, 0xC1, 0xF3, 0x80, 0x12, 0x9A, 0x42, 0x0C, 0xD0, 0x13, 0x46, 0x89, 0x06, 0xF6, 0xD5,
  7.     0x01, 0x88, 0x21, 0x60, 0xC1, 0xF3, 0x80, 0x12, 0x01, 0x88, 0x21, 0x60, 0xC1, 0xF3, 0x80, 0x11,
  8.     0x91, 0x42, 0x01, 0xD1, 0x00, 0x20, 0x10, 0xBD, 0xF0, 0x21, 0x01, 0x80, 0x01, 0x20, 0x10, 0xBD,
  9.     0x3F, 0x49, 0x49, 0x44, 0x48, 0x60, 0x00, 0x20, 0x70, 0x47, 0x00, 0x20, 0x70, 0x47, 0x30, 0xB5,
  10.     0x3B, 0x4C, 0xAA, 0x21, 0x4C, 0x44, 0x60, 0x68, 0xA0, 0xF8, 0xAA, 0x1A, 0x55, 0x22, 0xA0, 0xF8,
  11.     0x54, 0x25, 0x80, 0x23, 0xA0, 0xF8, 0xAA, 0x3A, 0xA0, 0xF8, 0xAA, 0x1A, 0xA0, 0xF8, 0x54, 0x25,
  12.     0x10, 0x21, 0xA0, 0xF8, 0xAA, 0x1A, 0x4F, 0xF6, 0xFF, 0x75, 0x60, 0x68, 0xFF, 0xF7, 0xC0, 0xFF,
  13.     0x08, 0xB1, 0x01, 0x20, 0x30, 0xBD, 0x60, 0x68, 0x00, 0x88, 0xA8, 0x42, 0xF5, 0xD1, 0x00, 0x20,
  14.     0x30, 0xBD, 0x30, 0xB5, 0x04, 0x46, 0x2A, 0x48, 0xAA, 0x21, 0x48, 0x44, 0x40, 0x68, 0xA0, 0xF8,
  15.     0xAA, 0x1A, 0x55, 0x22, 0xA0, 0xF8, 0x54, 0x25, 0x80, 0x23, 0xA0, 0xF8, 0xAA, 0x3A, 0xA0, 0xF8,
  16.     0xAA, 0x1A, 0xA0, 0xF8, 0x54, 0x25, 0x30, 0x20, 0x20, 0x80, 0x21, 0x49, 0x49, 0x44, 0x20, 0x88,
  17.     0x08, 0x60, 0x00, 0x07, 0xFB, 0xD5, 0x4F, 0xF6, 0xFF, 0x75, 0x20, 0x46, 0xFF, 0xF7, 0x98, 0xFF,
  18.     0x08, 0xB1, 0x01, 0x20, 0x30, 0xBD, 0x20, 0x88, 0xA8, 0x42, 0xF6, 0xD1, 0x00, 0x20, 0x30, 0xBD,
  19.     0x2D, 0xE9, 0xF0, 0x4D, 0x04, 0x46, 0xF0, 0x20, 0x15, 0x46, 0x20, 0x80, 0xDF, 0xF8, 0x50, 0x80,
  20.     0x00, 0x26, 0x4F, 0xF0, 0xAA, 0x0A, 0xC8, 0x44, 0x4F, 0xF0, 0x55, 0x0B, 0x01, 0xF1, 0x01, 0x0C,
  21.     0x18, 0xE0, 0xD8, 0xF8, 0x04, 0x00, 0xA0, 0xF8, 0xAA, 0xAA, 0xA0, 0xF8, 0x54, 0xB5, 0xA0, 0x21,
  22.     0xA0, 0xF8, 0xAA, 0x1A, 0x28, 0x88, 0x20, 0x80, 0x2F, 0x88, 0x20, 0x46, 0xFF, 0xF7, 0x70, 0xFF,
  23.     0x10, 0xB1, 0x01, 0x20, 0xBD, 0xE8, 0xF0, 0x8D, 0x20, 0x88, 0xB8, 0x42, 0xF5, 0xD1, 0xAD, 0x1C,
  24.     0xA4, 0x1C, 0x76, 0x1C, 0xB6, 0xEB, 0x5C, 0x0F, 0xE3, 0xD3, 0x00, 0x20, 0xF2, 0xE7, 0x00, 0x00,
  25.     0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
  26. };
  27. const program_target_t flash_algo = {
  28.     0x20000061,         // Init
  29.     0x2000006B,         // UnInit
  30.     0x2000006F,         // EraseChip
  31.     0x200000B3,         // EraseSector
  32.     0x20000101,         // ProgramPage
  33.     //0x00000000,         // CheckBlank
  34.     //0x00000000,         // Verify
  35.     // BKPT : start of blob + 1
  36.     // RSB  : address to access global/static data
  37.     // RSP  : stack pointer
  38.     {
  39.     0x20000001,
  40.     0x20000570,
  41.     0x20002000
  42.     },
  43.     0x20000170,         // mem buffer location
  44.     0x20000000,         // location to write prog_blob in target RAM
  45.     sizeof(flash_code), // prog_blob size
  46.     flash_code,         // address of prog_blob
  47.     0x00000400,         // ram_to_flash_bytes_to_be_written
  48. };
CortexM FLASH算法提取器.rar (37.95 KB, 下载次数: 445)
参与人数 1金币 +10 收起 理由
摸鱼校尉 + 10 很给力!
 楼主| 发表于 2026-3-19 11:15:48 | 显示全部楼层
2026年3月19
版本更新到V0.5
0.运行库更新到 .net framework 4.8(win10及以上自带);
1.修复 高分辨率显示器显示模糊的问题;
2.检查更新优化。
CMFA_Tool V0.5.rar
36.59 KB, 下载次数: 21
发表于 2021-5-15 13:30:47 | 显示全部楼层
牛逼啊.....!
发表于 2022-9-9 13:44:35 | 显示全部楼层
请问这个地方的地址是如何能直接从文件中获取的呢?
    0x20000061,         // Init
发表于 2022-9-9 14:35:47 | 显示全部楼层
    0x20000 ...
对. FLM里面可以提取出来。
发表于 2022-9-9 16:06:20 | 显示全部楼层
如果我需要将上面的这个文件,打包为一个bin文件,然后通过ota穿到ram中,后面烧录其他程序的时候使用。
这个bin文件,应该如何生成呢?
发表于 2022-9-9 17:24:46 | 显示全部楼层
已经想到办法了,可以直接在工程文件中做单独位置加载。
然后通过mdk的fromelf 命令,分为2个文件,应该是可以的。
类似原来的字库的做法。
发表于 2023-3-24 17:33:32 | 显示全部楼层
非常好,感谢感谢
发表于 2023-6-20 10:28:25 | 显示全部楼层
大佬 有没有源码分享一下
发表于 2024-6-11 21:27:55 | 显示全部楼层
为啥不同的算法转换软件转出来的 函数入口地址会有差异?而且有些函数转换不全呢?
函数不全嘛,还好理解。但入口地址不一样,这个不会出错吗?
 楼主| 发表于 2024-6-17 09:10:46 | 显示全部楼层
函数不全嘛,还好理 ...
还有这种事情?肯定是识别错了
发表于 2025-1-20 15:05:30 | 显示全部楼层
XXFXXXXXXX
发表于 2025-1-20 15:05:59 | 显示全部楼层
非常好,感谢感谢
发表于 2025-1-22 17:18:50 | 显示全部楼层
非常好,感谢感谢
发表于 2025-8-18 13:11:22 | 显示全部楼层
NB,标记一下
发表于 2025-12-4 09:15:45 | 显示全部楼层
    0x20000 ...
大佬,这个提取规则搞明白了嘛,可以教教我嘛
发表于 2025-12-5 11:35:12 | 显示全部楼层
FLM 文件实际上就是axf文件,换了个后缀。
这边编译的时候,就是选择的位置无关编译
对于axf文件,实际上是可以用objdump这些工具分析出来的。
楼主位置的工具解析的时候,多了32个字节的头,那边原本目的是为了按照顺序方init deinit这些函数的位置的。
所以,只要有这些位置无关的二进制代码,就可以将他定位到ram中任意位置,按照函数接口进去调用,就能实现相关功能。
发表于 2025-12-5 14:27:17 | 显示全部楼层
不错不错,mark一下
发表于 2026-3-17 17:33:12 | 显示全部楼层
生成的FLM文件,使用jflash烧录时提示出错:
ERROR: PC of target system has unexpected value affter preparing target. (PC = 0x4770BA40)!
通过上面的算法提取器发现这个地址就和algo code里的符合,查看map文件和代码没什么问题。代码在ram里运行是正确的。会是什么原因造成的呢?
algo code:
00 BE 0A E0 0D 78 2D 06 68 40 08 24 40 00 00 D3
58 40 64 1E FA D1 49 1C 52 1E 00 2A F2 D1 70 47
40 BA 70 47 40 BA 70 47 40 BA 70 47 40 BA 70 47
C0 BA 70 47 C0 BA 70 47 C0 BA 70 47 C0 BA 70 47
发表于 2026-3-19 09:25:00 | 显示全部楼层
ERROR: PC of target system has unexpected value affter pr ...
方便的话,分享个FLM到百度云,我看下,
发表于 2026-4-30 14:36:20 | 显示全部楼层
你编译完不就是bin吗
发表于 2026-7-24 15:29:32 | 显示全部楼层
感谢楼主分享,
GMT+8, 2026-11-22 13:04 , Processed in 0.433785 second(s), 30 queries .
