查看: 5347|回复: 3
[SEGGER RTT] SEGGER RTT最新目标板软件包V6.89
发表于 2021-3-15 10:19:20 | 显示全部楼层 |阅读模式
SEGGER_RTT_V698a.zip (42.56 KB, 下载次数: 71)
  1. README.txt for the SEGGER RTT Implementation Pack.
  2. MDK-ARM specifics:
  3. https://wiki.segger.com/Keil_MDK-ARM#RTT_in_uVision
  4. Included files:
  5. ===============
  6. Root Directory
  7.   - Examples
  8.     - Main_RTT_InputEchoApp.c    - Sample application which echoes input on Channel 0.
  9.     - Main_RTT_MenuApp.c         - Sample application to demonstrate RTT bi-directional functionality.
  10.     - Main_RTT_PrintfTest.c      - Sample application to test RTT small printf implementation.
  11.     - Main_RTT_SpeedTestApp.c    - Sample application for measuring RTT performance. embOS needed.
  12.   - RTT
  13.     - SEGGER_RTT.c                - The RTT implementation.
  14.     - SEGGER_RTT.h                - Header for RTT implementation.
  15.     - SEGGER_RTT_Conf.h           - Pre-processor configuration for the RTT implementation.
  16.     - SEGGER_RTT_Printf.c         - Simple implementation of printf to write formatted strings via RTT.
  17.   - Syscalls
  18.     - RTT_Syscalls_GCC.c          - Low-level syscalls to retarget printf() to RTT with GCC / Newlib.
  19.     - RTT_Syscalls_IAR.c          - Low-level syscalls to retarget printf() to RTT with IAR compiler.
  20.     - RTT_Syscalls_KEIL.c         - Low-level syscalls to retarget printf() to RTT with KEIL/uVision compiler.
  21.     - RTT_Syscalls_SES.c          - Low-level syscalls to retarget printf() to RTT with SEGGER Embedded Studio.
发表于 2021-3-16 08:58:28 | 显示全部楼层
相对上个版本(v6.96)就改个版本号注释,也太划水了
发表于 2021-3-16 20:40:20 | 显示全部楼层
大佬,请教下这个下载的官方路径能提供下嘛
 楼主| 发表于 2021-3-17 08:08:09 | 显示全部楼层
在JLINK驱动软件包里面。
下载JLINK驱动就可以了。
GMT+8, 2026-11-24 11:47 , Processed in 0.259463 second(s), 27 queries .
