查看: 5687|回复: 0
[硬件三角函数Cordic] H730硬件三角函数使用DMA方式,推荐开启突发传输,性能提升一倍多
发表于 2021-3-13 09:49:43 | 显示全部楼层 |阅读模式
备份代码如下:
  1. void HAL_CORDIC_MspInit(CORDIC_HandleTypeDef* hcordic)
  2. {
  3.   if(hcordic->Instance==CORDIC)
  4.   {
  5.     /* Peripheral clock enable */
  6.     __HAL_RCC_CORDIC_CLK_ENABLE();
  7.
  8.     /* CORDIC DMA Init */
  9.     /* CORDIC_WRITE Init */
  10.     hdma_cordic_write.Instance = DMA1_Stream0;
  11.     hdma_cordic_write.Init.Request = DMA_REQUEST_CORDIC_WRITE;
  12.     hdma_cordic_write.Init.Direction = DMA_MEMORY_TO_PERIPH;
  13.     hdma_cordic_write.Init.PeriphInc = DMA_PINC_DISABLE;
  14.     hdma_cordic_write.Init.MemInc = DMA_MINC_ENABLE;
  15.     hdma_cordic_write.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
  16.     hdma_cordic_write.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
  17.     hdma_cordic_write.Init.Mode = DMA_NORMAL;
  18.     hdma_cordic_write.Init.Priority = DMA_PRIORITY_LOW;
  19.     hdma_cordic_write.Init.FIFOMode            = DMA_FIFOMODE_ENABLE;
  20.     hdma_cordic_write.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
  21.     hdma_cordic_write.Init.MemBurst            = DMA_MBURST_INC4;
  22.     hdma_cordic_write.Init.PeriphBurst         = DMA_PBURST_SINGLE;
  23.     if (HAL_DMA_Init(&hdma_cordic_write) != HAL_OK)
  24.     {
  25.     }
  26.     __HAL_LINKDMA(hcordic,hdmaIn,hdma_cordic_write);
  27.     /* CORDIC_READ Init */
  28.     hdma_cordic_read.Instance = DMA1_Stream1;
  29.     hdma_cordic_read.Init.Request = DMA_REQUEST_CORDIC_READ;
  30.     hdma_cordic_read.Init.Direction = DMA_PERIPH_TO_MEMORY;
  31.     hdma_cordic_read.Init.PeriphInc = DMA_PINC_DISABLE;
  32.     hdma_cordic_read.Init.MemInc = DMA_MINC_ENABLE;
  33.     hdma_cordic_read.Init.PeriphDataAlignment = DMA_PDATAALIGN_WORD;
  34.     hdma_cordic_read.Init.MemDataAlignment = DMA_MDATAALIGN_WORD;
  35.     hdma_cordic_read.Init.Mode = DMA_NORMAL;
  36.     hdma_cordic_read.Init.Priority = DMA_PRIORITY_LOW;
  37.     hdma_cordic_read.Init.FIFOMode            = DMA_FIFOMODE_ENABLE;
  38.     hdma_cordic_read.Init.FIFOThreshold       = DMA_FIFO_THRESHOLD_FULL;
  39.     hdma_cordic_read.Init.MemBurst            = DMA_MBURST_INC4;
  40.     hdma_cordic_read.Init.PeriphBurst         = DMA_PBURST_SINGLE;
  41.     if (HAL_DMA_Init(&hdma_cordic_read) != HAL_OK)
  42.     {
  43.     }
  44.     __HAL_LINKDMA(hcordic,hdmaOut,hdma_cordic_read);
  45.   }
  46. }
GMT+8, 2026-10-26 05:56 , Processed in 0.116964 second(s), 24 queries .
