查看: 5069|回复: 1
[DSP] DSP库中的arm_sin_q31函数是查表实现,精度略低,大概到11到12个bit
发表于 2021-3-13 09:35:00 | 显示全部楼层 |阅读模式
原始数据:
0x00000000, 0x04000000, 0x08000000, 0x0C000000,
  0x10000000, 0x14000000, 0x18000000, 0x1C000000,
  0x20000000, 0x24000000,
理论结果:
0x00000000, 0x0C8BD35E, 0x18F8B83C, 0x25280C5D,
  0x30FBC54D, 0x3C56BA70, 0x471CECE6, 0x5133CC94,
  0x5A827999, 0x62F201AC,
实际求得结果:
 楼主| 发表于 2021-3-13 09:36:02 | 显示全部楼层
实现代码:
  1. /* ----------------------------------------------------------------------
  2. * Project:      CMSIS DSP Library
  3. * Title:        arm_sin_q31.c
  4. * Description:  Fast sine calculation for Q31 values
  5. *
  6. * $Date:        18. March 2019
  7. * $Revision:    V1.6.0
  8. *
  9. * Target Processor: Cortex-M cores
  10. * -------------------------------------------------------------------- */
  11. /*
  12. * Copyright (C) 2010-2019 ARM Limited or its affiliates. All rights reserved.
  13. *
  14. * SPDX-License-Identifier: Apache-2.0
  15. *
  16. * Licensed under the Apache License, Version 2.0 (the License); you may
  17. * not use this file except in compliance with the License.
  18. * You may obtain a copy of the License at
  19. *
  20. * www.apache.org/licenses/LICENSE-2.0
  21. *
  22. * Unless required by applicable law or agreed to in writing, software
  23. * distributed under the License is distributed on an AS IS BASIS, WITHOUT
  24. * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  25. * See the License for the specific language governing permissions and
  26. * limitations under the License.
  27. */
  28. #include "arm_math.h"
  29. #include "arm_common_tables.h"
  30. /**
  31.   @ingroup groupFastMath
  32. */
  33. /**
  34.   @addtogroup sin
  35.   @{
  36. */
  37. /**
  38.   @brief         Fast approximation to the trigonometric sine function for Q31 data.
  39.   @param[in]     x  Scaled input value in radians
  40.   @return        sin(x)
  41.   The Q31 input value is in the range [0 +0.9999] and is mapped to a radian value in the range [0 2*PI).
  42. */
  43. q31_t arm_sin_q31(
  44.   q31_t x)
  45. {
  46.   q31_t sinVal;                                  /* Temporary variables for input, output */
  47.   int32_t index;                                 /* Index variable */
  48.   q31_t a, b;                                    /* Two nearest output values */
  49.   q31_t fract;                                   /* Temporary values for fractional values */
  50.   if (x < 0)
  51.   { /* convert negative numbers to corresponding positive ones */
  52.     x = (uint32_t)x + 0x80000000;
  53.   }
  54.   /* Calculate the nearest index */
  55.   index = (uint32_t)x >> FAST_MATH_Q31_SHIFT;
  56.   /* Calculation of fractional value */
  57.   fract = (x - (index << FAST_MATH_Q31_SHIFT)) << 9;
  58.   /* Read two nearest values of input value from the sin table */
  59.   a = sinTable_q31[index];
  60.   b = sinTable_q31[index+1];
  61.   /* Linear interpolation process */
  62.   sinVal = (q63_t) (0x80000000 - fract) * a >> 32;
  63.   sinVal = (q31_t) ((((q63_t) sinVal << 32) + ((q63_t) fract * b)) >> 32);
  64.   /* Return output value */
  65.   return (sinVal << 1);
  66. }
  67. /**
  68.   @} end of sin group
  69. */
GMT+8, 2026-10-26 05:56 , Processed in 0.126954 second(s), 27 queries .
