查看: 5652|回复: 2
[emWin] 十分怪异,无法解释的现象。。关于EMWIN。
发表于 2021-2-13 10:02:37 | 显示全部楼层 |阅读模式
static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] =
        { WINDOW_CreateIndirect,         "Window", ID_WINDOW_0,                         0, 0, 800, 570, 0, 0x0, 0},
        { IMAGE_CreateIndirect,                NULL,         GUI_ID_IMAGE0,                         0, 0, 800, 570,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_I_1,                         590, 82, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_I_2,                         590, 127, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_V_1,                         590, 177, 130, 50,        0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_V_2,                         590, 222, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_W_1,                         590, 272, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_W_2,                         590, 317, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_R_1,                         590, 367, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_R_2,                         590, 412, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_SHIFT,                         590, 462, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_STRESS,                 590, 507, 130, 50,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_I_UP,                         346, 520, 68, 30,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_V_UP,                         417, 520, 68, 30,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_W_UP,                         490, 520, 68, 30,         0, 0, 0 },
        { TEXT_CreateIndirect,                 NULL,         ID_TEXT_NORM,                         630, 54, 40, 20,         0, 0, 0 },
        { TEXT_CreateIndirect,                 "kA",         ID_TEXT_D1,                         730, 148, 40, 20,         0, 0, 0 },
        { TEXT_CreateIndirect,                 "V",         ID_TEXT_D2,                         730, 243, 40, 20,         0, 0, 0 },
        { TEXT_CreateIndirect,                 "kW",         ID_TEXT_D3,                         730, 338, 40, 20,         0, 0, 0 },
        { TEXT_CreateIndirect,                 "mR",         ID_TEXT_D4,                         730, 433, 40, 20,         0, 0, 0 },
        { TEXT_CreateIndirect,                 "Pa",         ID_TEXT_D5,                         730, 483, 40, 20,         0, 0, 0 },
        { TEXT_CreateIndirect,                 "mm",         ID_TEXT_D6,                         730, 528, 40, 20,         0, 0, 0 },
如上的结构中,如果只要TEXT的显示内容包括'a',那么在界面切换时,画面就有撕裂感,猛的闪烁一次。如果没有字符'a',即使换成大写的'A',都不会有这个问题。。。。。。。这是为什么??????
发表于 2021-2-13 21:07:45 | 显示全部楼层
发个完整的模拟器测试程序,我试试。emWin版本是多少。
 楼主| 发表于 2021-2-13 22:32:13 | 显示全部楼层
发现是MDK中的IROM1和IROM2空间合并导致的。。合并居然会导致这意想不到的结果。。
GMT+8, 2026-11-23 20:33 , Processed in 0.218056 second(s), 24 queries .
