查看: 7041|回复: 4
[ThreadX全家桶] 最简单方式的ThreadX GUIX窗口滑动操作没搞定。。。(已解决)
发表于 2020-12-17 12:23:17 | 显示全部楼层 |阅读模式
实现两个窗口滑动切换的方法,测试了只能滑动一次。。。
1、先在root上创建了一个
gx_studio_named_widget_create("window", (GX_WIDGET *)root, (GX_WIDGET **)&pScreen);
2、再创建两个,附加到pScreen上
gx_studio_named_widget_create("window_1", (GX_WIDGET *)GX_NULL, (GX_WIDGET **)&pScreen1);
gx_studio_named_widget_create("window_2", (GX_WIDGET *)GX_NULL, (GX_WIDGET **)&pScreen2);
gx_widget_attach((GX_WIDGET *)pScreen, (GX_WIDGET *)pScreen1);
gx_widget_attach((GX_WIDGET *)pScreen, (GX_WIDGET *)pScreen2);
3、然后创建动画对象
gx_animation_create(&slide_animation);
slide_animation_start((GX_WINDOW *)pScreen2);
函数的实现
weather_win_list[0] = (GX_WIDGET *)pScreen1;
weather_win_list[1] = (GX_WIDGET *)pScreen2;
weather_win_list[2] = (GX_WIDGET *)GX_NULL;
static VOID slide_animation_start(GX_WINDOW *window1)
    GX_ANIMATION_INFO slide_animation_info;
    memset(&slide_animation_info, 0, sizeof(GX_ANIMATION_INFO));
    slide_animation_info.gx_animation_parent = (GX_WIDGET *)window1;
    slide_animation_info.gx_animation_style = GX_ANIMATION_SCREEN_DRAG | GX_ANIMATION_HORIZONTAL | GX_ANIMATION_WRAP | GX_ANIMATION_SINE_EASE_OUT;
    slide_animation_info.gx_animation_id = GX_NEXT_ANIMATION_ID;
    slide_animation_info.gx_animation_frame_interval = 1;
    slide_animation_info.gx_animation_steps = 10;
    slide_animation_info.gx_animation_slide_screen_list = weather_win_list;
    gx_animation_drag_enable(&slide_animation, (GX_WIDGET *)window1, &slide_animation_info);
 楼主| 发表于 2020-12-17 18:43:06 | 显示全部楼层
终于成功了。。。。。。。。。。。。。。。。。。。。。。
发表于 2020-12-17 18:58:58 | 显示全部楼层
牛逼的狠辣,俺目前看着就头疼哟
发表于 2020-12-17 19:20:55 | 显示全部楼层
真是不容易啊……
发表于 2020-12-17 19:24:10 | 显示全部楼层
硬汉辛苦了
GMT+8, 2026-11-23 20:03 , Processed in 1.752213 second(s), 24 queries .
