查看: 5297|回复: 5
[emWin] emwin 仪表盘显示有撕裂现象
发表于 2020-12-9 17:12:27 | 显示全部楼层 |阅读模式
问题如题,刷新显示的时候屏乱闪。感觉指针刷新和文本更新有冲突,还请各位大神帮忙分析一下原因。主要代码如下:
*       _aDialogCreate
        { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 800, 480, 0, 0x0, 0 },
  { PROGBAR_CreateIndirect, "Progbar", ID_PROGBAR_0, 363, 31, 20, 98, 1, 0x0, 0 },
  { PROGBAR_CreateIndirect, "Progbar", ID_PROGBAR_1, 416, 31, 20, 95, 1, 0x0, 0 },
  { TEXT_CreateIndirect, "Throtle", ID_TEXT_0, 346, 136, 54, 20, 0, 0x64, 0 },
  { TEXT_CreateIndirect, "Speed", ID_TEXT_1, 140, 225, 146, 99, 0, 0x64, 0 },
  { TEXT_CreateIndirect, "RPM", ID_TEXT_2, 520, 225, 155, 87, 0, 0x64, 0 },
  { TEXT_CreateIndirect, "Brake", ID_TEXT_3, 415, 135, 52, 20, 0, 0x64, 0 },
  { TEXT_CreateIndirect, "Time", ID_TEXT_4, 365, 385, 80, 20, 0, 0x64, 0 },
  // USER START (Optionally insert additional widgets)
  // USER END
*       _cbDialog
  WM_HWIN hItem;
  GUI_AUTODEV AutoDev;      /* 内存设备 */
  PARAM       Param;        /* PARAM类型变量 */
  char TextSpeed[16];
  char TextRpm[16];
  static int                 t_Count0 = 0;// -a by Trun 20200311
  static int                 t_Count1 = 0;// -a by Trun 20200311
  static int                 t_Count2 = 0;// -a by Trun 20200311
  static int         t0 = 360;   /* 用于三个指针的计数 */
  static int         t1 = 360;
  static int         t2 = 360;
  static int         Dir0 = 1;
  static int         Dir1 = 1;
  // USER END
  switch (pMsg->MsgId) {
  case WM_INIT_DIALOG:
          hItem = WM_GetDialogItem(pMsg->hWin, ID_PROGBAR_0);
          PROGBAR_SetBarColor(hItem, 0, GUI_BLUE);
          PROGBAR_SetBarColor(hItem, 1, GUI_ORANGE);
          hItem = WM_GetDialogItem(pMsg->hWin, ID_PROGBAR_1);
    // Initialization of 'Text'
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_1);
        hText[0] = hItem;
    TEXT_SetTextAlign(hItem, GUI_TA_HCENTER | GUI_TA_VCENTER);
    TEXT_SetFont(hItem, GUI_FONT_D24X32);
    TEXT_SetTextColor(hItem, GUI_MAKE_COLOR(0x00C08080));
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_2);
        hText[1] = hItem;
    hItem = WM_GetDialogItem(pMsg->hWin, ID_TEXT_4);
    hText[2] = hItem;
    TEXT_SetFont(hItem, GUI_FONT_8X16_1);
    TEXT_SetTextColor(hItem, GUI_MAKE_COLOR(0x00C0C0C0));
    // USER START (Optionally insert additional code for further widget initialization)
        /* 使能抗锯齿 */
        GUI_AA_EnableHiRes();
        /* 设置抗锯齿因数 */
        GUI_AA_SetFactor(MAG);
        /* 创建自动设备对象 */
        GUI_MEMDEV_CreateAuto(&AutoDev);
    // USER END
  // USER START (Optionally insert additional message handling)
  // USER END
        /* 重绘消息 */
  case WM_PAINT:
          /* 第一个指针计数,用于旋转速度 */
          t0-= 10;
          if (t0< 0)
                  t0 = 36000;
          /* 第二个指针计数,用于旋转速度 */
          t1 -= 10;
          if (t1 < 0)
                  t1 = 36000;
          /* 旋转第一个指针 */
          Param.Angle = t0;
          Param.Angle *= 3.1415926f / 18000;
          GUI_RotatePolygon(Param.aPoints, _aNeedle, countof(_aNeedle), Param.Angle);
          /* 旋转第二个指针 */
          Param.Angle1 = t1;
          Param.Angle1 *= 3.1415926f / 18000;
          GUI_RotatePolygon(Param.aPoints1, _aNeedle1, countof(_aNeedle1), Param.Angle1);
          GUI_MEMDEV_DrawAuto(&AutoDev, &Param.AutoDevInfo, &_Draw, &Param);
          //更新文本显示
          sprintf((char*)TextSpeed, "%d", (t0 + 12000) / 100);
          sprintf((char*)TextRpm, "%d", t1 / 100);
          TEXT_SetText(hText[0], TextSpeed);
          TEXT_SetText(hText[1], TextRpm);
  default:
    WM_DefaultProc(pMsg);
*       Public code
*       CreateWindow
WM_HWIN CreateWindow(void);
WM_HWIN CreateWindow(void) {
  WM_HWIN hWin;
  hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
  return hWin;
*        函 数 名: MainTask
*        功能说明: GUI主函数
*        形    参:无
*        返 回 值: 无
void MainTask(void)
        GUI_Init();
        WM_MULTIBUF_Enable(1);                        //开启STemWin多缓冲,RGB屏可能会用到
        while (1)
                CreateWindow();
                GUI_Delay(100);
发表于 2020-12-9 19:05:11 | 显示全部楼层
直接跑我这个时钟表盘的例子是否正常
【年末福利】F429开发板12期emWin提高篇实战例程发布,含音视频播放器,uCOS-III和FreeRTOS两个版本
https://forum.anfulai.cn/forum.p ... 3687&fromuid=58
发表于 2020-12-9 19:51:06 | 显示全部楼层
while (1)
     CreateWindow();
     GUI_Delay(100);
这代码逻辑不对呀。不断的创建新窗口,然后新窗口更新表盘指针位置。还好是模拟器,实际下到板子上很快就挂了吧。
窗口只创建一次,刷新由定时器触发。建议先看看论坛里的emwin资料。
 楼主| 发表于 2020-12-10 08:34:07 | 显示全部楼层
eric2013 发表于 2020-12-9 19:05
直接跑我这个时钟表盘的例子是否正常
【年末福利】F429开发板12期emWin提高篇实战例程发布,含音视频播 ...
谢谢,是我没把例程完全看懂,现在已经解决了。
 楼主| 发表于 2020-12-10 08:35:31 | 显示全部楼层
有梦为马 发表于 2020-12-9 19:51
while (1)
     CreateWindow();
仔细研究例程,其实比较简单,没理解透例程,问题复杂化了。谢谢了
发表于 2020-12-10 10:47:08 | 显示全部楼层
好的,后面还有什么问题,再交流。
GMT+8, 2026-11-23 19:58 , Processed in 0.997458 second(s), 27 queries .
