楼主: WillyTerra
[其它] Arm Development Studio补丁包
发表于 2022-7-25 14:18:50 | 显示全部楼层
2022.0 windows 版本激活失败,报了 Warning: Failure when connecting to port "27000" on hostname "192.158.245.128",大家有遇到这个问题吗 ?
 楼主| 发表于 2022-7-26 22:31:47 | 显示全部楼层
nickxwei 发表于 2022-7-25 14:18
2022.0 windows 版本激活失败,报了 Warning: Failure when connecting to port "27000" on hostname "192. ...
直接打开编译看下
发表于 2022-7-28 09:55:09 | 显示全部楼层
求助求助!新人求助!!!
在执行model configuration的时候就提示 license checkout failed 了
执行顺序如下:File > new > other > configuration database > model configuration
具体错误如图:
有没有大佬帮忙指导一下的
 楼主| 发表于 2022-7-29 22:15:31 | 显示全部楼层
板砖人柱力 发表于 2022-7-28 09:55
求助求助!新人求助!!!
执行顺序 ...
多谢反馈,网盘patch已经更新
你可以直接下载该附件并覆盖到sw/ide/plugins目录下即可
com.arm.licensing_2022.1.0.20220715_140425.jar
2.11 MB, 下载次数: 35
patch
发表于 2022-8-5 10:20:33 | 显示全部楼层
大佬 这个问题能不能看一下
发表于 2022-8-5 15:18:56 | 显示全部楼层
telnetterminal0: Listening for serial connection on port 5000
telnetterminal1: Listening for serial connection on port 5001
telnetterminal2: Listening for serial connection on port 5002
Fatal: license error: Failed to set license mapping
In file: F:\work\fastsim\Framework\scx\SCXSimulationEngine.cpp:2930
Error: license error: The expected environment for the virtual platform has not been configured. This could be because the virtual platform was not started from the executable in <installdir>/bin or because your copy of the product has not been activated yet. To activate your copy of the product, start the IDE and and complete the license setup wizard.
In file: F:\work\fastsim\Framework\scx\SCXSimulationEngine.cpp:3271
Error: license error: Simulation Engine module unavailable!
In file: F:\work\fastsim\Framework\scx\SCXSimulationEngine.cpp:2870
ERROR: uncaught exception occurred. Exception message follows:
Error: Wrong version of armctmodel. Version 11.18.16 (API Version 1.2) of the Portfolio was used to build the model. Please use identical major.minor versions of the Portfolio and the Tools.
 楼主| 发表于 2022-8-5 22:49:48 | 显示全部楼层
telnetterminal1: Listening for serial ...
多谢反馈,已经更新。你可以使用附件拷贝到models\bin文件夹下替换
libMAXCOREInitSimulationEngine.3.dll
1.03 MB, 下载次数: 20
Update 2022-08-07
发表于 2022-8-6 00:26:19 | 显示全部楼层
这些涉及加解密的动态库都是有时间限制的吗 ???
还有我注意到在第一次仿真时 fvp.exe会去连接网络 这个是在鉴权吗 ???
发表于 2022-8-6 01:30:54 | 显示全部楼层
替换之后还是不ok啊
是不是因为我没有添加 LM_LICENSE 在系统中的原因啊  需要我收集其他信息协助你解决吗
 楼主| 发表于 2022-8-6 09:43:20 | 显示全部楼层
razor7788 发表于 2022-8-6 01:30
替换之后还是不ok啊
是不是因为我没有添加 LM_LICENSE 在系统中的原因啊  需要我收集其他信息 ...
显示不是报license错误,应该是别的原因了。
 楼主| 发表于 2022-8-6 09:45:11 | 显示全部楼层
还有我注意到在第一次仿真时 fvp.exe会去连接网络  ...
和license文件的时间是保持一致的,单独这个库没有时间限制
 楼主| 发表于 2022-8-6 11:20:28 | 显示全部楼层
替换之后还是不ok啊
论坛不方便交流,发我微信或qq
发表于 2022-9-6 12:10:48 | 显示全部楼层
Can you share ds_rowan_suite activation code ?
INCREMENT ds_rowan_suite armlmd 0.1 30-apr-2099 uncounted \
        17E713FB0264 HOSTID=ANY ISSUER="ARM Limited" \
        NOTICE="Cracked by WillyTerra" \
        SN=  SIGN=""
 楼主| 发表于 2022-9-6 23:13:03 | 显示全部楼层
INCREMENT ds_rowan_suite armlmd 0.1 30-apr-2099 un ...
When you replace data with patched, activation code is not nessary.
发表于 2022-12-7 16:08:38 | 显示全部楼层
 楼主| 发表于 2022-12-23 21:39:14 | 显示全部楼层
bobdeng2007 发表于 2022-12-7 16:08
使用最新的网盘文件,依旧出现错误,Windows版本。
目前更新了最新版本2022.2,请下载试试
 楼主| 发表于 2022-12-23 21:47:02 | 显示全部楼层
发表于 2023-4-26 14:02:06 | 显示全部楼层
linux版本的话 license如何启动。请说明一下前辈。谢谢
 楼主| 发表于 2023-4-28 14:10:10 | 显示全部楼层
./lmgrd -c ds_license.dat -l log.txt你也可以创建服务后台运行
 楼主| 发表于 2023-4-29 22:25:00 | 显示全部楼层
软件已经更新到2023.0
发表于 2023-5-4 17:12:04 | 显示全部楼层
楼主,我安装了2021.1,ADS的IDE的授权管理中,也添加了lic,显示是golden edition
但是,打开streamline时,却显示license错误:
用不了streamline。
请问,有遇到这个问题吗?
 楼主| 发表于 2023-5-4 21:46:55 | 显示全部楼层
还是用新版本吧,旧版本我没在维护了
发表于 2023-5-5 16:55:34 | 显示全部楼层
你好,版主,
我破解了2022.2后无法使用arm compiler 6 了
在属性页面添加时显示“fail to add.....”
下载并使用5的时候提示license error
发表于 2023-5-5 16:59:01 | 显示全部楼层
WillyTerra 发表于 2023-5-4 21:46
还是用新版本吧,旧版本我没在维护了
你好,Willy
我使用了您的2022.2 crack后原本的 arm compiler 6消失了,
下载arm compiler 5.06 p7后提示 license error。
请问在覆盖后还需要做什么工作吗?
敬礼,
Alex
发表于 2023-5-6 09:39:30 | 显示全部楼层
实测后21.1版可以使用,22.2,23.0都无法通过arm compiler 6 licnse
 楼主| 发表于 2023-5-7 09:22:05 | 显示全部楼层
不能吧?你覆盖安装了吗?我测试是可以的
 楼主| 发表于 2023-5-7 09:40:01 | 显示全部楼层
编译没有任何问题呀
发表于 2023-5-8 11:41:20 | 显示全部楼层
WillyTerra 发表于 2023-5-7 09:40
编译没有任何问题呀
那我再用另一个电脑试试,可能环境变量被改变了
发表于 2023-5-8 16:21:04 | 显示全部楼层
请问楼主有没有arm compiler 5 的破解,,原来索引的是5 的编译器(ARM 你坏事做尽)
发表于 2023-5-18 18:01:36 | 显示全部楼层
感谢持续分享
发表于 2023-6-6 17:47:44 | 显示全部楼层
感谢楼主分享!!!
发表于 2023-6-26 15:28:40 | 显示全部楼层
dll不能下载,是因为没评论吗?
发表于 2023-6-30 11:34:42 | 显示全部楼层
先赞再用
发表于 2023-6-30 13:29:36 | 显示全部楼层
请问一下如何把 Arm Compiler 6 单独抽出来用
发表于 2023-8-3 18:36:38 | 显示全部楼层
hello,
  下载了2023 Linux的版本,也按Readme.txt执行了,但是还没有破解成功,streamline不能用,
  ______                        _______________
/_  __/__  ____ _____ ___     / ____/ ____/   |
  / / / _ \/ __ `/ __ `__ \   / __/ / /_  / /| |
/ / /  __/ /_/ / / / / / /  / /___/ __/ / ___ |
/_/  \___/\__,_/_/ /_/ /_/  /_____/_/   /_/  |_|
1. Install ARM Development Studio 2023.0.
2. Copy patch files folder to directory and replace file.
3. Set ARMLMD_LICENSE_FILE=<license file in ARM DS directory>
4. All Done!
by Team EFA.
发表于 2023-8-3 18:39:12 | 显示全部楼层
hello,
  我下载了2023 Linux版本,也按Readme.txt执行了,但是还没破解成功,Streamline有问题。
4. All Done!
by Team EFA.
发表于 2023-8-19 22:30:41 | 显示全部楼层
感谢大佬无私奉献
发表于 2023-8-19 22:33:17 | 显示全部楼层
错误103:非法下载,请返回主站重新下载,这是需要发表评论后才能下载吗
发表于 2023-8-29 04:40:20 | 显示全部楼层
都是9年义务教育,你为何如此优秀?这个cracked 的原理可以简单说说吗?让我也开开眼界
发表于 2023-8-29 06:08:47 | 显示全部楼层
楼主有以前旧版本的吗?  比如linux 下的 rvds 4.1 3.1的license
GMT+8, 2026-10-12 21:13 , Processed in 0.779574 second(s), 22 queries .
