返回列表 发新帖
楼主: eric2013
【安富莱】STemWin,μCGUI常见问题整理帖
发表于 2014-4-4 16:58:36 | 显示全部楼层
版主,请教个emwin对话框切换的问题。
就是我想实现这样的功能,按下ESC键从对话框一跳到对话框二,但现在跳到对话框二后就死机,版主请问对话框切换程序要怎么写,以下是我的代码,要怎么修改才能实现对话框切换,非常感谢。
void MainTask(void) {//主函数
  GUI_Init();
  WM_SetCallback(WM_HBKWIN, _cbBkWindow);
  GUI_ExecDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), &_cbCallback, 0, 0, 0);//创建对话框一
static void _cbCallback(WM_MESSAGE * pMsg) {//对话框一的回调函数
  int i;
  int NCode, Id;
  WM_HWIN hDlg, hItem;
  hDlg = pMsg->hWin;
  switch (pMsg->MsgId) {
    case WM_INIT_DIALOG:
      hItem = WM_GetDialogItem(hDlg, GUI_ID_RADIO0);
      for (i = 0; i < GUI_COUNTOF(_apLabel); i++) {
        RADIO_SetText(hItem, _apLabel, i);
      _SetFont(hDlg);
       case WM_KEY:
      switch (((WM_KEY_INFO*)(pMsg->Data.p))->Key) {
        case GUI_KEY_ESCAPE:
            WM_DeleteWindow(hDlg);
             ExecSetup();
    case WM_NOTIFY_PARENT:
      Id    = WM_GetId(pMsg->hWinSrc);    /* Id of widget */
      NCode = pMsg->Data.v;               /* Notification code */
      switch (NCode) {
      case WM_NOTIFICATION_VALUE_CHANGED: /* Value has changed */
        _SetFont(hDlg);
      case WM_NOTIFICATION_RELEASED:      /* React only if released */
        if (Id == GUI_ID_OK) {            /* OK Button */
          GUI_EndDialog(hDlg, 0);
        if (Id == GUI_ID_CANCEL) {        /* Cancel Button */
          GUI_EndDialog(hDlg, 1);
    default:
      WM_DefaultProc(pMsg);
void ExecSetup(void)//建立对话框二
  GUI_Init();
  WM_SetCallback(WM_HBKWIN, &_cbBkWindow);
  WM_SetCreateFlags(WM_CF_MEMDEV);  // Use memory devices on all windows to avoid flicker
static void _cbCallback(WM_MESSAGE * pMsg) {//对话框二回调函数
  WM_HWIN hDlg;
  WM_HWIN hItem;
  int     Sel;
  int     NCode;
  int     Id;
  GUI_PID_STATE * pState;
  hDlg = pMsg->hWin;
      hItem = WM_GetDialogItem(hDlg, GUI_ID_EDIT0);
      EDIT_SetDecMode(hItem, 30,   0, 999, 0, 0);    // Select decimal mode
      WM_DisableWindow(hItem);
    case WM_KEY:
        case GUI_KEY_ENTER:
    case WM_TOUCH_CHILD:
      Id = WM_GetId(pMsg->hWinSrc);      // Id of widget
      switch (Id) {
        case GUI_ID_TEXT0:
        case GUI_ID_TEXT1:
        case GUI_ID_TEXT2:
          pState = (GUI_PID_STATE *)((WM_MESSAGE *)pMsg->Data.p)->Data.p;
          if (pState) {
            if (pState-&gtressed) {
              WM_HWIN hRadio = WM_GetDialogItem(hDlg, GUI_ID_RADIO0);
              RADIO_SetValue(hRadio, Id - GUI_ID_TEXT0);    // Use the text beside the radio button to
                                                            // set the value of the radio button
      NCode = pMsg->Data.v;                 // Notification code
      switch (NCode) {
        case WM_NOTIFICATION_RELEASED:      // React only if released
          switch (Id) {
            case GUI_ID_OK:
            case GUI_ID_CANCEL:
          Sel   = RADIO_GetValue(hItem);
          WM_SetEnableState(hItem, Sel == 2);
    default:
 楼主| 发表于 2014-4-4 17:06:02 | 显示全部楼层
回 roger 的帖子
roger:版主,请教个emwin对话框切换的问题。
  GUI_Init .. (2014-04-04 16:58)
可以新建立一个帖子讨论
发表于 2014-4-9 17:54:57 | 显示全部楼层
[s:150]
发表于 2014-6-12 09:59:08 | 显示全部楼层
[s:150]
发表于 2014-6-16 23:30:15 | 显示全部楼层
必须支持一下
发表于 2014-12-29 18:00:57 | 显示全部楼层
[s:141]  [s:141]  [s:141]
发表于 2015-1-1 18:32:41 | 显示全部楼层
Listbox项目不知道为什么删除不干净?使用for循环调用deleteltem。
GMT+8, 2026-11-23 06:51 , Processed in 0.355451 second(s), 29 queries .
