楼主: eric2013
[ThreadX全家桶] ThreadX全家桶所有组件综合模板发布,史上最强安全认证综合模板,稳如泰山,含AC5,AC6,IAR和GCC(2023-12-23)
发表于 2021-2-1 10:16:26 | 显示全部楼层
终于发布了,给力
代码不规范,亲人两行泪!
发表于 2021-2-1 10:18:09 | 显示全部楼层
给力
---日期错了
发表于 2021-2-1 11:12:23 | 显示全部楼层
ThreadX全家桶开源了   用于商用还需要取得授权么
 楼主| 发表于 2021-2-1 11:15:43 | 显示全部楼层
免费厂家列表,还在持续更新:
  1. LICENSED HARDWARE LIST
  2. Last Updated: 2020-12-15
  3. Microsoft has entered into OEM Agreements with manufacturers of the following
  4. microprocessors and microcontrollers (the “hardware”) to enable those
  5. manufacturers to include and distribute Azure RTOS in certain hardware. If you
  6. have obtained and/or are developing on microprocessor(s) and/or
  7. microcontroller(s) (“hardware”) listed below you inherit the “Distribution and
  8. Production Use” rights in Section 2 of the Microsoft Software License Terms for
  9. Microsoft Azure RTOS. If hardware is not listed below, you do not have those
  10. rights.
  11. STMicroelectronics:
  12.     STM32 MCUs
  13.     STM32 MPUs
  14. MediaTek:
  15.     MT3620 MCU (Azure Sphere)
  16. Microchip:
  17.     PIC 32-bit MCUs
  18.     SAM 32-bit MCUs
  19.     SAM 32-bit MPUs
  20. NXP:
  21.     NXP i.MX RT10xx series crossover MCUs
  22. Renesas:
  23.     Synergy Platform
  24.     RX Family of MCUs
  25.     RZ Family of MPUs
  26. --------------------------------------------------------------------------------
  27. More coming soon. Please check back frequently for updates.
发表于 2021-2-1 11:26:27 | 显示全部楼层
坐等硬汉哥的教程。
 楼主| 发表于 2021-2-1 11:30:18 | 显示全部楼层
812126060 发表于 2021-2-1 11:26
坐等硬汉哥的教程。
ThreadX内核和GUIX教程,论坛上已发。
发表于 2021-2-1 11:53:09 | 显示全部楼层
好厉害,我用笔记本i7-8550u编译了12分钟。
 楼主| 发表于 2021-2-1 13:30:46 | 显示全部楼层
byccc 发表于 2021-2-1 10:18
给力
---日期错了
已经修改。
发表于 2021-2-2 09:55:40 | 显示全部楼层
发表于 2021-2-2 09:57:06 | 显示全部楼层
发表于 2021-2-2 15:57:39 | 显示全部楼层
请问楼主用的IAR是8.5几的?
 楼主| 发表于 2021-2-3 09:05:04 | 显示全部楼层
wxfpuw001 发表于 2021-2-2 15:57
请问楼主用的IAR是8.5几的?
下载IAR官网上的那个最新版就行。
发表于 2021-2-3 13:13:53 | 显示全部楼层
感谢分享!
发表于 2021-2-3 14:03:46 | 显示全部楼层
膜拜呀!
More we do, more we can do.
发表于 2021-2-5 16:35:34 | 显示全部楼层
还是想请教一下ThreadX Modules动态加载的原理
 楼主| 发表于 2021-2-5 16:45:57 | 显示全部楼层
还没用过,需要后面学习学习。
发表于 2021-2-14 11:27:54 | 显示全部楼层
异常强大,留名跟帖,长期关注!
发表于 2021-2-16 11:24:25 | 显示全部楼层
请问 有计划出  V5 的 ThreadX全家桶吗?
发表于 2021-2-16 15:21:18 | 显示全部楼层
R5 3600 16GDDR4  500G 固盘  win10   64 位  PC, 开虚拟机 win7 32位, 分配 2核4线程,AC5
编译 仅需420 秒。
看来 笔记本 真不给力
发表于 2021-2-16 15:50:06 | 显示全部楼层
R5 3600 16GDDR4  500G 固盘  win10   64 位  PC  6核 12 线程,keil  5.33 。
AC5 编译 仅需80 秒。 AC6 编译 仅需100 秒。CPU 瞬间活动  100%
 楼主| 发表于 2021-2-17 09:36:52 | 显示全部楼层
V5和V6都会做。
发表于 2021-2-26 14:03:53 | 显示全部楼层
老大辛苦了,强大到没朋友。
发表于 2021-3-14 08:39:34 | 显示全部楼层
eric2013 发表于 2021-1-29 08:10
做,动态模块那个要独立的做新的综合Demo,后面搞。
动态模块什么时候到桶里来,期待它全家~~~
发表于 2021-3-14 16:40:38 | 显示全部楼层
编译模板工程都要10分钟。。。
发表于 2021-3-14 16:56:16 | 显示全部楼层
我用AC6编译,开browse info,足足编译了19分45秒,真的太夸张了。。。
 楼主| 发表于 2021-3-27 08:13:04 | 显示全部楼层
那你的电脑的确是太卡,这个AC6开brower info仅仅是开启,还并没有执行。
需要等待底栏进度条满了才可以。
发表于 2021-4-23 21:10:39 | 显示全部楼层
需要等待底栏进度条满了才可 ...
感觉 mdk 的话,建议还是使用 ac5 比较好,编译速度比 ac6 快,而且还支持中文名的路径及文件名,
反正现在使用 mdk 编译 stm hal 库的单片机文件,也习惯了关闭 brower info  功能,要查找某个函数直接全局搜索完事
 楼主| 发表于 2021-4-24 11:06:48 | 显示全部楼层
反 ...
快,还是AC6快一些。
发表于 2021-4-28 11:03:26 | 显示全部楼层
这个版本我试用了一下,打印信息都是乱码,不知道是什么问题。串口 波特率115200,1停止位,其他没有。串口工具试过SecureCRT,串口助手等很多软件,都一样。编译用过IAR 9.1.0, MDK5.33,编码格式用过UTF-8,GB2312,ANSI,都不行。啥原因啊
 楼主| 发表于 2021-4-28 11:09:39 | 显示全部楼层
zhang0352505 发表于 2021-4-28 11:03
这个版本我试用了一下,打印信息都是乱码,不知道是什么问题。串口 波特率115200,1停止位,其他没有。串口 ...
你在V7上测试的,还是你移植的,V7上没问题。
发表于 2021-4-28 13:03:32 | 显示全部楼层
直接用的V7的,因为公司只有V7的 开发板,没移植,拿来编译就下载的
 楼主| 发表于 2021-4-28 13:47:37 | 显示全部楼层
编译的那个版本,我测试下。
发表于 2021-4-28 14:05:02 | 显示全部楼层
就是从楼主位下载的这个版本,
*        修改记录 :
*                版本号   日期         作者            说明
*       V1.0    2021-01-30   Eric2013    1. ST固件库1.9.0版本
*                                        2. BSP驱动包V1.2
*                                        3. ThreadX版本V6.0
*                                        4. GUIX版本V6.0
*                                        5. FileX版本V6.1.3
*                                        6. NetXDUO版本V6.1.3
*                                        7. USBX版本V6.1.3
*        Copyright (C), 2021-2030, 安富莱电子 www.armfly.com
 楼主| 发表于 2021-4-28 14:33:20 | 显示全部楼层
zhang0352505 发表于 2021-4-28 14:05
就是从楼主位下载的这个版本,
*        修改记录 :
*                版本号   日期         作者            说明
我是说你是编译的AC5,AC6,IAR还是GCC
发表于 2021-4-28 15:16:20 | 显示全部楼层
MDK用的AC6, IAR用的IAR
 楼主| 发表于 2021-4-28 16:12:08 | 显示全部楼层
zhang0352505 发表于 2021-4-28 15:16
MDK用的AC6, IAR用的IAR
帮你测试了下,没问题。
发表于 2021-5-10 09:05:34 | 显示全部楼层
gcc文件编辑器用的啥?sourinsight感觉宏多了就傻了
 楼主| 发表于 2021-5-10 12:03:28 | 显示全部楼层
看Embedded Studio的工程,是GCC的
发表于 2021-5-27 12:15:48 | 显示全部楼层
支持 USB 读取 FILEX 文件吗
 楼主| 发表于 2021-5-27 17:36:03 | 显示全部楼层
质的飞跃 发表于 2021-5-27 12:15
支持 USB 读取 FILEX 文件吗
模拟U盘,底层接口的API使用FileX的api?
GMT+8, 2026-11-16 09:21 , Processed in 1.627802 second(s), 25 queries .
