查看: 5367|回复: 3
[有问必答] STM32F407使用ADC1和ADC3快速交叉采样没数据
发表于 2018-2-8 10:35:55 | 显示全部楼层 |阅读模式
在例程双ADC快速采样的基础上修改的,首先把8位分辨率改成了12位分辨率,测试OK,然后想改成ADC1和ADC3快速交叉采样,把ADC2改成了ADC3其他没有修改,测试没有采集到数据,请问ADC1和ADC3可以配置成双ADC快速交叉采样吗?需要怎么配置?我看了下好像没什么地方要修改了啊!源码如下:
/* define ---------------------------------------------------------------------*/
#define ADC_CDR_ADDRESS    ((uint32_t)0x40012308)
/* 变量 ----------------------------------------------------------------------*/
__IO uint32_t uhADCDualConvertedValue;
*        函 数 名: bsp_InitADC
*        功能说明: ADC初始化
*        形    参: 无
*        返 回 值: 无
void bsp_InitADC(void)
    ADC_InitTypeDef       ADC_InitStructure;
    ADC_CommonInitTypeDef ADC_CommonInitStructure;
    DMA_InitTypeDef       DMA_InitStructure;
    GPIO_InitTypeDef      GPIO_InitStructure;
    /* 使能 ADC1, ADC2, DMA2 和 GPIO 时钟 ****************************************/
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA, ENABLE);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2 |
                                                   RCC_APB2Periph_ADC3, ENABLE);
    /* DMA2 Stream0 channel0 配置 **************************************/
    DMA_InitStructure.DMA_Channel = DMA_Channel_0;
        DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC_CDR_ADDRESS;
        DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&uhADCDualConvertedValue;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
        DMA_InitStructure.DMA_BufferSize = 1;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Word;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Word;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
        DMA_InitStructure.DMA_Priority = DMA_Priority_High;
        DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
        DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
        DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
        DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
        DMA_Init(DMA2_Stream0, &DMA_InitStructure);
    DMA_Cmd(DMA2_Stream0, ENABLE);
    /* 配置ADC引脚为模拟输入模式******************************/
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
          PCLK2 = HCLK / 2
          下面选择的是2分频
          ADCCLK = PCLK2 /4 = HCLK / 4 = 168 / 4 = 42M
      双ADC采样频率: 42 / 6 = 7Mbps
    /* ADC公共部分初始化**********************************************************/
    ADC_CommonInitStructure.ADC_Mode = ADC_DualMode_Interl;
    ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_6Cycles;
    ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_2;
    ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
    ADC_CommonInit(&ADC_CommonInitStructure);
    ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
        ADC_InitStructure.ADC_ScanConvMode = DISABLE;
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
        ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
        ADC_InitStructure.ADC_NbrOfConversion = 1;
    /* ADC1 规则通道配置 -------------------------------------------------------*/
        ADC_Init(ADC1, &ADC_InitStructure);
        ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
//        /* ADC2 规则通道配置 -------------------------------------------------------*/
//        ADC_Init(ADC2, &ADC_InitStructure);
//        ADC_RegularChannelConfig(ADC2, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
    /* ADC3 规则通道配置 -------------------------------------------------------*/
        ADC_Init(ADC3, &ADC_InitStructure);
        ADC_RegularChannelConfig(ADC3, ADC_Channel_0, 1, ADC_SampleTime_3Cycles);
    /* 使能 ADC1 DMA */
        ADC_DMACmd(ADC1, ENABLE);
        /* 使能DMA请求 (多ADC模式) --------------------------------------------------*/
        ADC_MultiModeDMARequestAfterLastTransferCmd(ENABLE);
        /* Enable ADC1 --------------------------------------------------------------*/
        ADC_Cmd(ADC1, ENABLE);
//        /* Enable ADC2 --------------------------------------------------------------*/
//        ADC_Cmd(ADC2, ENABLE);
    /* Enable ADC3 --------------------------------------------------------------*/
        ADC_Cmd(ADC3, ENABLE);
        /* 软件启动转换 */
        ADC_SoftwareStartConv(ADC1);
 楼主| 发表于 2018-2-8 11:03:45 | 显示全部楼层
看了下参考手册,发现在双从ADC模式下,不存在ADC3从器件,说明双从模式下只能使用ADC1和ADC2
发表于 2018-2-9 09:48:10 | 显示全部楼层
不好意思,楼主,现在才回复你。
不推荐用F4自带的双通道和三通道快速交替采样,效果比较差,推荐使用我们V5开发板示波器Demo里面的bsp_adc.c,使用ADC独立实现交替采样
发表于 2025-12-11 11:54:45 | 显示全部楼层
eric2013 发表于 2018-2-9 09:48
不好意思,楼主,现在才回复你。
不推荐用F4自带的双通道和三通道快速交替采样,效果比较差,推荐使用我 ...
你说的这个demo是这个吗?
(为什么我发的图片 显示一直转圈啊)
GMT+8, 2026-11-28 11:57 , Processed in 0.436350 second(s), 27 queries .
