查看: 1119|回复: 3
[开发工具] 再来一贴,官网提供这个分散加载文件好像有问题
发表于 2025-6-21 21:20:12 | 显示全部楼层 |阅读模式
看了一下H7这个MDMA的链式传输,想着前几天刚好加载文件没搞好,这里刚好看到这有分散加载文件
但是一看好像有点问题,H723的SRAM没这么大吧,再一看好像地址都重叠了,还能这样定义吗?
发表于 2025-6-22 01:45:24 | 显示全部楼层
重叠应该不会允许吧,编译能通过吗,其他例程也这样?
发表于 2025-6-22 08:22:19 | 显示全部楼层
分配有误
[C] 纯文本查看 复制代码
#define D1_ITCMRAM_BASE           (0x00000000UL) /*!< Base address of : 64KB RAM reserved for CPU execution/instruction accessible over ITCM  */
#define D1_ITCMICP_BASE           (0x00100000UL) /*!< Base address of : (up to 128KB) embedded Test FLASH memory accessible over ITCM         */
#define D1_DTCMRAM_BASE           (0x20000000UL) /*!< Base address of : 128KB system data RAM accessible over DTCM                            */
#define D1_AXIFLASH_BASE          (0x08000000UL) /*!< Base address of : (up to 1 MB) embedded FLASH memory accessible over AXI                */
#define D1_AXIICP_BASE            (0x1FF00000UL) /*!< Base address of : (up to 128KB) embedded Test FLASH memory accessible over AXI          */
#define D1_AXISRAM1_BASE           (0x24000000UL) /*!< Base address of : (up to 128KB) system data RAM1 accessible over over AXI                */
#define D1_AXISRAM2_BASE           (0x24020000UL) /*!< Base address of : (up to 192KB) system data RAM2 accessible over over AXI to be shared with ITCM (64K granularity)  */
#define D1_AXISRAM_BASE            D1_AXISRAM1_BASE /*!< Base address of : (up to 320KB) system data RAM1/2 accessible over over AXI             */
#define D2_AHBSRAM1_BASE          (0x30000000UL)   /*!< Base address of : (up to 16KB) system data RAM accessible over over AXI->AHB Bridge    */
#define D2_AHBSRAM2_BASE          (0x30004000UL)   /*!< Base address of : (up to 16KB) system data RAM accessible over over AXI->AHB Bridge    */
#define D2_AHBSRAM_BASE           D2_AHBSRAM1_BASE /*!< Base address of : (up to 32KB) system data RAM1/2 accessible over over AXI->AHB Bridge */
#define D3_BKPSRAM_BASE           (0x38800000UL) /*!< Base address of : Backup SRAM(4 KB) over AXI->AHB Bridge                                */
#define D3_SRAM_BASE              (0x38000000UL) /*!< Base address of : Backup SRAM(16 KB) over AXI->AHB Bridge                               */
#define PERIPH_BASE               (0x40000000UL) /*!< Base address of : AHB/APB Peripherals                                                   */
#define OCTOSPI1_BASE             (0x90000000UL) /*!< Base address of : OCTOSPI1 memories  accessible over AXI                                 */
#define OCTOSPI2_BASE             (0x70000000UL) /*!< Base address of : OCTOSPI2 memories  accessible over AXI                                 */
#define FLASH_BANK1_BASE          (0x08000000UL) /*!< Base address of : (up to 1 MB) Flash Bank1 accessible over AXI                          */
#define FLASH_END                 (0x080FFFFFUL) /*!< FLASH end address        */
 楼主| 发表于 2025-6-22 11:53:53 | 显示全部楼层
编译没问题,这里好像没影响。
但是官网提供的这个例程的时钟配置好像也有问题,初始化直接死在时钟配置这里,我后面改了几次,降频一半都没成功,后面从别的工程复制了一个时钟配置函数过来才跑起来。
GMT+8, 2026-10-24 13:29 , Processed in 0.134030 second(s), 27 queries .
