查看: 1509|回复: 4
[问题已解决]【求助】F469使用FMC驱动IS45S16400J异常
发表于 2025-6-10 08:29:57 | 显示全部楼层 |阅读模式
问题解决:Solved: Missing SDNWE signal using STM32F469NI and SDRAM o... - STMicroelectronics Community
F469/479系列手册和CUBEMX中显示fmc_sdnwe可以用PA7和PC0,但是实际上PA7是无效的,只能用PC0,ST官方没有修改手册和CUBEMX的配置
鼓捣了好几天没弄明白,发出来球各位大佬指教
使用cubemx生成的FMC初始化,根据网上找的F429驱动同款芯片的资料微调了SDRAM初始化函数
目前现象是,写入test[0],读test[0]能读出写入的数据,然后写入test[1],再次读[0]和[1],读出的都是最后一次写入[1]的数据。
用万用表量引脚,数据和地址脚正常,但是WE脚始终是低电平,看手册上读的时候这个脚应该是高
目前怀疑1.FMC初始化失败,但是这块是CUBE生成的,按理说不应该
2.地址映射有误,目前没有找到F469的映射资料,F429的FMC SDRAMbank2对应的是0xD0000000,查了一下F429和469在地址映射上应该是没有差别的
附上CUBEMX配置情况及SDRAM初始化代码,主频180Mhz,开了FMC中断
void MX_SDRAM_InitEx(void)
  __IO uint32_t tmpmrd = 0;
  FMC_SDRAM_CommandTypeDef Command;
  int ret = 0;
  /* Step 1: Configure a clock configuration enable command */
  Command.CommandMode            = FMC_SDRAM_CMD_CLK_ENABLE;
  Command.CommandTarget          =  FMC_SDRAM_CMD_TARGET_BANK2;
  Command.AutoRefreshNumber      = 1;
  Command.ModeRegisterDefinition = 0;
  /* Send the command */
  while(HAL_SDRAM_GetState(&hsdram1) == HAL_SDRAM_STATE_BUSY)
  ret = HAL_SDRAM_SendCommand(&hsdram1, &Command, SDRAM_TIMEOUT);
  printf("SDRAM_Init: Step 1: Configure a clock configuration enable command, ret = %d\r\n", ret);
  /* Step 2: Insert 100 us minimum delay */
  /* Inserted delay is equal to 1 ms due to systick time base unit (ms) */
  HAL_Delay(100);
  /* Step 3: Configure a PALL (precharge all) command */
  Command.CommandMode            = FMC_SDRAM_CMD_PALL;
  printf("SDRAM_Init: Step 3: Configure a PALL (precharge all) command, ret = %d\r\n", ret);
  HAL_Delay(100);
  /* Step 4: Configure an Auto Refresh command */
  Command.CommandMode            = FMC_SDRAM_CMD_AUTOREFRESH_MODE;
  Command.AutoRefreshNumber      = 8;
  printf("SDRAM_Init: Step 4: Configure an Auto Refresh command, ret = %d\r\n", ret);
  HAL_Delay(100);
  /* Step 5: Program the external memory mode register */
  tmpmrd = (uint32_t)SDRAM_MODEREG_BURST_LENGTH_2          |\
                     SDRAM_MODEREG_BURST_TYPE_SEQUENTIAL      |\
                     SDRAM_MODEREG_CAS_LATENCY_3           |\
                     SDRAM_MODEREG_OPERATING_MODE_STANDARD |\
                     SDRAM_MODEREG_WRITEBURST_MODE_PROGRAMMED;
  Command.CommandMode            = FMC_SDRAM_CMD_LOAD_MODE;
  Command.ModeRegisterDefinition = tmpmrd;
  HAL_Delay(100);
  /* Step 6: Set the refresh rate counter */
  /* Set the device refresh rate */
  HAL_SDRAM_ProgramRefreshRate(&hsdram1, 1387);
  //HAL_Delay(100);
测试部分代码:
u16 testsram[1024] __attribute__((at(0xD0000000))) ;(全局变量)
  U16 temp = 0;
  //HAL_SDRAM_read_8b(&hsdram1,(uint32_t *)(testsram),(uint8_t *)&temp,1);
  printf("read testsram == %d\r\n",testsram[0]);
  temp = 123;
  HAL_SDRAM_Write_8b(&hsdram1,(uint32_t *)(testsram),(uint8_t *)&temp,1);
  printf("22read testsram == %d\r\n",testsram[0]);
  testsram[1] = 789;
  printf("22read testsram0 == %d  testsram1 == %d\r\n",testsram[0],testsram[1]);
发表于 2025-6-10 09:28:23 | 显示全部楼层
优先检查焊接,SDRAM问题,大部分都是硬件焊接问题。
 楼主| 发表于 2025-6-10 09:33:19 | 显示全部楼层
好的,我量一下
 楼主| 发表于 2025-6-10 15:10:20 | 显示全部楼层
问题解决,是ST的问题,手册中和CUBEMX都显示FMC_SDNWE可以由PA7和PC0复用,但是实际上在2016年就有人发现PA7脚是无效的,改用PC0读写SDRAM正常了。
问题:https://community.st.com/t5/stm3 ... -on-pa7/td-p/458567
废物ST更新了勘误表但是没更新手册和CUBE,气死我了
发表于 2025-6-10 15:33:25 | 显示全部楼层
missinlite 发表于 2025-6-10 15:10
问题解决,是ST的问题,手册中和CUBEMX都显示FMC_SDNWE可以由PA7和PC0复用,但是实际上在2016年就有人发现P ...
这bug防不胜防
GMT+8, 2026-11-25 09:34 , Processed in 0.742021 second(s), 27 queries .
