查看: 1991|回复: 2
流水灯编译报错问题怎么解决
发表于 2023-10-25 22:23:17 | 显示全部楼层 |阅读模式
Build started: Project: project
*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'F:\keil_v5\ARM\ARMCC\Bin'
Build target 'Flash'
*** Scatter Error: no default 'Read/Write' range selected
compiling bsp_timer.c...
Warning: C3912W: Option 'device' is deprecated.
Fatal error: C3903U: Argument '--fpu=softvfp+vfpv2' not permitted for option 'device'.
compiling bsp_key.c...
compiling stm32f4xx_it.c...
compiling main.c...
compiling bsp_uart_fifo.c...
compiling bsp_led.c...
compiling stm32f4xx_assert.c...
compiling bsp.c...
compiling bsp_ext_io.c...
compiling stm32f4xx_syscfg.c...
compiling stm32f4xx_usart.c...
compiling stm32f4xx_gpio.c...
compiling misc.c...
compiling stm32f4xx_rcc.c...
compiling stm32f4xx_fmc.c...
compiling stm32f4xx_tim.c...
compiling system_stm32f4xx.c...
assembling startup_stm32f429_439xx.s...
startup_stm32f429_439xx.s: Warning: A3912W: Option 'device' is deprecated.
startup_stm32f429_439xx.s: error: A3903U: Argument '-g' not permitted for option 'device'.
".\Flash\Obj\output.axf" - 18 Error(s), 18 Warning(s).
Target not created.
Build Time Elapsed:  00:00:01
发表于 2023-10-26 07:36:31 | 显示全部楼层
看着像是MDK安装失败了。换个盘符,重新安装换个版本试试。
 楼主| 发表于 2023-10-26 09:37:59 | 显示全部楼层
好的,之前这个用来编译f103的没问题,买了v6的板子,也安装了f4的库就是编译有错
GMT+8, 2026-11-25 10:11 , Processed in 0.214581 second(s), 24 queries .
