查看: 1913|回复: 0
[ThreadX全家桶] ThreadX获取任务创建列表使用变量_tx_thread_created_ptr
发表于 2022-9-25 14:30:38 | 显示全部楼层 |阅读模式
最近在做H7-TOOL的ThreadX Trace功能
变量:
[C] 纯文本查看 复制代码
/* Define the current thread pointer.  This variable points to the currently
   executing thread.  If this variable is NULL, no thread is executing.  */
THREAD_DECLARE  TX_THREAD *     _tx_thread_current_ptr;
/* Define the variable that holds the next thread to execute.  It is important
   to remember that this is not necessarily equal to the current thread
   pointer.  */
THREAD_DECLARE  TX_THREAD *     _tx_thread_execute_ptr;
/* Define the head pointer of the created thread list.  */
THREAD_DECLARE  TX_THREAD *     _tx_thread_created_ptr;
/* Define the variable that holds the number of created threads. */
THREAD_DECLARE  ULONG           _tx_thread_created_count;
GMT+8, 2026-11-23 23:41 , Processed in 0.745942 second(s), 27 queries .
