查看: 1998|回复: 0
[FileX] ThreadX FileX和LevelX升级至V6.1.10,FileX升级修改exFAT格式下固定Sector大小问题(2022-02-04)
发表于 2022-2-4 21:32:53 | 显示全部楼层 |阅读模式
论坛下载:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=97925
FileX更新记录:
  1. Files are modified to fix compiler errors or logics without cache:
  2.         common/src/fx_api.h
  3.         common/src/fx_directory_exFAT_free_search.c
  4.         common/src/fx_media_open.c
  5.         common/src/fx_utility_logical_sector_cache_entry_read.c
  6.         common/src/fx_utility_logical_sector_flush.c
  7.     Files are modified to remove fix sector size in exFAT and support all sizes as per specification :
  8.         common/inc/fx_api.h
  9.         common/inc/fx_user_sample.h
  10.         common/inc/fx_utility.h
  11.         common/src/fx_fault_tolerant_create_log_file.c
  12.         common/src/fx_media_exFAT_format.c
  13.         common/src/fx_media_boot_info_extract.c
  14.         common/src/fx_utility_exFAT_size_calculate.c
  15.         common/src/fx_utility_exFAT_goemetry_check.c
  16.         common/src/fx_utility_exFAT_sysytem_area_checksum_verify.c
  17.         common/src/fx_utility_exFAT_sysytem_area_checksum_write.c
  18.         common/src/fx_utility_exFAT_sysytem_area_format.c
  19.     File is modified to fix last character compare for last found name with new one:
  20.         common/src/fx_directory_search.c
复制代码
LevelX更新记录:
  1.    File is modified to update include order standalone usage of LevelX:
  2.         common/inc/lx_api.h
复制代码
GMT+8, 2026-11-22 13:15 , Processed in 0.248937 second(s), 24 queries .
