查看: 2110|回复: 0
[ThreadX全家桶] ThreadX GUIX和GUIX Studio升级至V6.1.10(2022-02-04)
发表于 2022-2-4 21:25:00 | 显示全部楼层 |阅读模式
论坛下载:
https://forum.anfulai.cn/forum.php?mod=viewthread&tid=97925
更新记录:
  1. New features for the 6.1.10 release:
  2.     Supported adjust needle position for radial slider widget.
  3. Improved logic for 6.1.10 release:
  4.     Improved text scroll wheel draw to support transparency.
  5.     Corrected Win32 display driver window size.
  6.     Fixed bidi-text base direction issue.
  7.     Fixed vertical/horizontal list total rows/columns set issue.
  8.     Fixed circular gauge dirty area caululation error.
  9.     Fixed canvas pixelmap rotate error when the rotation center is not the center of the image.
  10.     Updated Win32 simulation driver to improve timer accuracy.
  11.     Fixed Win32 simulation driver issue that event thread blocks lower priority ThreadX threads.
  12.     Fixed bug in gx_sprite_update() function which allowed widget to update after application calls sprite_stop after timer had expired.
  13.     Fixed circular gauge dirty mark issue caused by widget resize.
复制代码
GMT+8, 2026-11-23 22:34 , Processed in 0.199864 second(s), 27 queries .
