查看: 5836|回复: 10
[ThreadX全家桶] Tracealyzer发布ThreadX SMP多核跟踪调试支持
发表于 2021-2-19 08:43:15 | 显示全部楼层 |阅读模式
 楼主| 发表于 2021-2-19 08:46:40 | 显示全部楼层
发表于 2021-2-19 15:43:28 | 显示全部楼层
这个有X机吗
代码不规范,亲人两行泪!
 楼主| 发表于 2021-2-19 16:53:51 | 显示全部楼层
好像没有,评估板也能用一段时间。
发表于 2021-2-20 13:35:50 | 显示全部楼层
azure rtos 商用要付费呀,不知道不付钱微软会不会发现
 楼主| 发表于 2021-2-20 14:01:22 | 显示全部楼层
免费商用厂家列表,还在持续增加中
https://github.com/azure-rtos/th ... CENSED-HARDWARE.txt
  1. LICENSED HARDWARE LIST
  2. Last Updated: 2020-12-15
  3. Microsoft has entered into OEM Agreements with manufacturers of the following
  4. microprocessors and microcontrollers (the “hardware”) to enable those
  5. manufacturers to include and distribute Azure RTOS in certain hardware. If you
  6. have obtained and/or are developing on microprocessor(s) and/or
  7. microcontroller(s) (“hardware”) listed below you inherit the “Distribution and
  8. Production Use” rights in Section 2 of the Microsoft Software License Terms for
  9. Microsoft Azure RTOS. If hardware is not listed below, you do not have those
  10. rights.
  11. STMicroelectronics:
  12.     STM32 MCUs
  13.     STM32 MPUs
  14. MediaTek:
  15.     MT3620 MCU (Azure Sphere)
  16. Microchip:
  17.     PIC 32-bit MCUs
  18.     SAM 32-bit MCUs
  19.     SAM 32-bit MPUs
  20. NXP:
  21.     NXP i.MX RT10xx series crossover MCUs
  22. Renesas:
  23.     Synergy Platform
  24.     RX Family of MCUs
  25.     RZ Family of MPUs
  26. --------------------------------------------------------------------------------
  27. More coming soon. Please check back frequently for updates.
复制代码
发表于 2021-2-20 21:06:49 | 显示全部楼层
感谢硬汉哥分享
等下我去X一下试试  4.3.x版本前的移植文档我看过 基本没啥用还不如用traceX
附上移植到Threadx的文档链接:https://percepio.com/docs/ThreadX/manual/
这是Freertos的 https://percepio.com/docs/FreeRTOS/manual/index.html
这是Ucos的  https://percepio.com/docs/Micrium/
 楼主| 发表于 2021-2-21 09:07:36 | 显示全部楼层
abcde1224 发表于 2021-2-20 21:06
感谢硬汉哥分享
附上移植 ...
现在这个版本能实时跟踪了没
发表于 2021-2-21 12:01:06 | 显示全部楼层
eric2013 发表于 2021-2-21 09:07
现在这个版本能实时跟踪了没
还不行 没更新多少东西  保存运行信息的方法和我之前写的那个TraceX的帖子使用方法基本一致 还是需要把跟踪日志写入设置好的内存区域再读取出来保存为trx文件  再拖到tracealyzer中去   就是看起来比较直观  贴几张我把咱那个V6-2002例程的运行结果拖进起的图,监控的内存我分配了500*128字节,也只保存了0.99s的数据,抽空我再整理下怎么自动将监控内存的文件追加写入trx文件,连同X的方法一起放出来 memory.trx (175.84 KB, 下载次数: 0)
 楼主| 发表于 2021-2-21 15:23:51 | 显示全部楼层
abcde1224 发表于 2021-2-21 12:01
还不行 没更新多少东西  保存运行信息的方法和我之前写的那个TraceX的帖子使用方法基本一致 还是需要把跟 ...
谢谢,效果的确不错,能实时跟踪就更爽了。
发表于 2021-2-21 19:34:01 | 显示全部楼层
今天翻了翻论坛  看到有坛友发了这个软件的和谐方法 下面这个帖子中的13楼
https://forum.anfulai.cn/forum.php?m ... 70&highlight=tracex
这个坛友的压缩包里面有个地址  我的方法和这个差不多吧 反正都是照着吾爱大神的来做的
http://elmagnifico.tech/2020/03/13/Tracealyzer-Crack/
至于激活码 注册个非国内邮箱,再找个非国内IP去那个软件下载页面  缺啥的申请一下啥的就有了 国内邮箱和ip地址已经收不到激活码了 微信截图_20210221192612.png
GMT+8, 2026-11-24 21:09 , Processed in 0.351736 second(s), 27 queries .
